Computer fans making a zzz sound
Oakley999
289
My fans on my pc are making a electrical like sound, a zzz sound more like, no wires seem to be caught in the fans, and one of my fans make a stronger sound then the rest, you can only hear it close with your ear next to it, but is this normal? is doesnt sound healthy at all.
Could be power supply noise try the fan in another computer see if same noise level. If the noise level is the same the fans might be dying.
I dont think its the power supply. when i hear the noise it sounds more centralized to it, as the front fan is way way away from the power supply, i've had this pc for nearly 2 years, but if they all sound like that it may be normal i guess.
No I mean the power supply dieing giveing off to much noise into the power that goes into the fans. This could effect the fans with changes in voltage.
It may be vibration from either the fans or the HDD, i have a cooler master cm 690 ii case and its known to not be silent, i've still got a warranty on my pc for like, another 3 years, so i'll worry about it until it blows up, thanks anyway!
