As the title says my computer has been freezing and makes a booping noise whenever I click the mouse. I cannot Ctrl/Alt/Delete, I have to either push the restart or power button +7 secs and restart it that way. This can occur anywhere from 5 minutes to a couple of hours. There is no error nothing, just freezes, and mouse cursor won't move. On top of that, sometimes when I restart my monitors won't start up either. I have to sometimes do 2-3 restarts to get my monitors connected (HDMI not found). I have the monitor plugged into the GPU and I have once removed it and put it into the MB HDMI slot which worked but then stopped working the next morning.
I am not currently in the GPU. I have also uninstalled GPU drivers and did a clean install and didn't seem to work. I'm unsure as to what exactly could be the problem. I haven't taken it apart and cleaned it nor does a computer reset. I'm hoping I can fix the problem before taking it all apart. Any ideas? Any one else experienced a situation like this? Very frustrating, feels like a time bomb every time I start up my PC because I don't know what to expect.
Specs:
MB - MSI Z170A Gaming M5
CPU: i7-6700K 4GHz
GPU: Geforce GTX 980 Ti
RAM: 16GB
OS: Windows 10
Thank you
Specs:
CPU: i7-6700K 4GHz
RAM: 16GB
OS: Windows 10
Thank you
