Computer Freezes with a couple Quick, Soft Buzzing Sounds. Screen Freezes, but Audio Continues. Requires Hard Reboot.
Mar 19, 2018
8
So I've been experiencing this issue almost daily for about around two months and I'm at my wit's end trying to find a solution to this problem. My computer will completely freeze, usually while playing games, but sometimes also during casual Internet browsing. During these freezes, I may here a couple quick and soft buzzing sounds (only a split second long each), and the screen will freeze, but the audio will continue, albeit it will continue with a couple quirk and cutting in and out a little bit. (I don't want this to get confused with the much more common issue experienced with a loud buzzing sound and total freeze or audio looping like I see on many forums.) Crtl + Alt + Delete doesn't work and I have to manually shut down my computer for a reset. Typically the issues occur during loading screens in games, or within several seconds after closing a game, though it has occasionally happened mid game as well or while not even in any game. Sometimes I can make this issue occur while Alt +Tabbing away from a game as well, which I know is a known bug with Windows 10 Creators update a while ago, but I'm not sure that's related. I've spent days browsing different forum sights for possible solutions, and so far nothing seems to have fixed it. Here are the solutions I've tried so far:
- Cleared out any dust from inside my case.
- Uninstalling and reinstalling the games I would play.
- Clearing game cache.
- Using built in scan and repair functions for the games.
- Lowered in-game graphic settings
- Updated graphic's card drivers will a clean install.
- Rolled back to known stable graphic's card drivers.
- Disabled screen overlays.
- Disabled file protection in Avast Antivirus.
- Disabled non necessary audio drivers.
- Updated GPU BIOS.
- Clean install of Windows 10.
- Tested each RAM stick individually using Windows Memory Diagnostics Tool (Extended) as well as memtest86 for several hours (showed no errors).
- Reseated the GPU and RAM (used alternate slots for the RAM).
- Started using MSI Afterburner with custom fan curve to more accurately monitor and control temps.
As you can see I began to doubt my problems where caused by files or drivers or settings and instead began looking into physical, hardware issues. I continue on with these troubleshoots to no avail:
- Tried using only one RAM stick at a time (issue persisted with both).
- Unplugged secondary monitor from computer, problem still persisted.
- RMA-ed my GPU, installed the new one, problem still persisted.
- Got a new power supply unit, with more wattage, problem still persisted.
I'm hoping that the issue is not motherboard or CPU related, but I'm thinking at this point it might just well be unless anyone has any more idea as to what may be causing this issue. My computer is only about 6 months old since I built it, and I never experienced any issues until just a month or two ago. Here are the specs:
OS: Windows 10 (x64) (build # 1709)
CPU: AMD Ryzen 7 1700x @3.4GHz 8-Core Processor
GPU: EVGA GeForce GTX 1080 TI 11GB SC2
Motherboard: ASRock AB350M Pro4 ATX AM4
Powersupply: EVGA SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX (now using a 850 watt one, my PC only requires 484)
RAM: G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200
Storage: Samsung 850 EVO-Series 500GB 2.5'' SSD
I also have plenty of case fans and a Corsair H100i v2 CFM Liquid Cooler for my CPU. I don't think it's an overheating issue as it sometimes happens during non-stressed casual use. Although at the same time I have been able to make the freeze happen during stress tests as well. And even during the heaviest use my temps only get up to 75°C max during very high video settings on a 1440p 144hz monitor. I think it's also worth noting that I have my PC plugged directly to a wall outlet. I have also swapped out some of the cables within the case itself as well. As far as other subtleties that I noticed about the issue, there is that my PC will seem more likely to freeze up during normal use if it has just recently frozen during gaming. When it freezes it will most often just stay like that with the quirky audio continuing. There have been occasions where it's frozen and quickly rebooted itself though during normal, non-gaming use however. Please let me know if there are any other pieces of information that I can provide. I really just want to figure out exactly what the issue truly is and be able to fix it and finally be done with it and have full use of my new PC back. Thanks in advanced for any help. Crossing my fingers on this one.
Sorry, I should have mentioned that the quick, soft buzzing sounds are digital, not mechanical. And if I'm not doing anything with audio they are absent from the freeze entirely.
I didn't think about the SSD. I guess there was no easy way to test it other than moving my OS and all my files over to it. I'll look into that some more for now.
I have updated all my drivers, and I have also resently updated my motherboard BIOS as well and the problems still occurs. The only components that I haven't ruled out for sure at this point are my SSD, CPU, and motherboard...
I have updated all my drivers, and I have also recently updated my motherboard BIOS as well and the problems still occurs. The only components that I haven't ruled out for sure at this point are my SSD, CPU, and motherboard...
