Fans power consumption is usually fairly small, but if a PSU is near it's operating limit the 5 fans might push power requirement over the limit.
The PSU may be failing. I've had similar issues, especially when trying to boot up the computer.
First, check that all cables, DIMM's, and video card are inserted properly.
If possible, get another known working PSU (at hand or borrow one) and try that instead. If there are no more problems then the original PSU is faulty. If problems persist, then remove the video card and use integrated video (if available), and/or use another video card.
If problems stop then the original video card is faulty. If problems continue, then try one DIMM at a time in each slot, and/or try other known working DIMM's.
If there are no further problems then the DIMM('s) and/or (some) memory slot(s) may be faulty. If problems persist then the motherboard appears to be faulty.
