Computer has no display and POST, after Processor Upgrade
indrolie
Commendable
Nov 9, 2016
8
Hi guys,
Good day.
I'm trying to upgrade my old computer processor, and I need some helps.
I have searched and follow the instructions from some threads but I'm still stuck with the problem.
So, I have an old computer with Intel Pentium 4 631 3.0Ghz processor, and I changed the processor to Intel Core 2 Duo e6600 (it's not a new one). After changed, there is no display on the monitor (monitor went to sleep) when starting up the computer. The CPU fan is running though, and the power LED is on too. But I don't hear any sound indicating the computer passed the POST. By the way, when I removed the RAM, there is unlimited short beep from the computer.
This is my computer specs:
Motherboard: ECS > P4M900T-M2 (V1.0)
RAM: Kingston kvr800d2n6/2g (2 pieces)
GPU: Nvidia Geforce 8600 GTS (I tried to remove the card and use onboard VGA too, to make sure it's not GPU problem).
PSU: Powerlogic Magnum Pro 275 (550w peak) (looks like this: https://www.google.com/search?q=Powerlogic+Magnum+Pro+275+(550w+peak)&client=firefox-b-ab&biw=1304&bih=671&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj28tmSz5vQAhVJvo8KHYCMBYwQ_AUIBigB#imgrc=kskZ-IPO74PmfM%3A)
Also, I have tried to:
1. Make sure the motherboard can support the new processor.
2. Update the BIOS to the latest version.
3. Change the RAM to Kingston kvr667d2n5/1g. (only 1 piece of RAM)
4. Reset the BIOS either with moving the jumper or remove the CMOS battery.
5. Unplug the power cable and hold computer power button for 30 seconds.
6. Checked the new processor (core 2 duo e6600), it is working in dell optiplex 780.
If I put back the old processor (Pentium 4 631), the computer is running well.
I running out of idea. Is there anything I missed? Please help
And I'm sorry for my bad english.
Regards
If you have the latest BIOS in the system, you either clicked in the CPU incorrectly or the CPU is bad (you said it was not new). According to the compatability list for that motherboard, it should run a e6600.
Hi,
But I have tried to re-seat the processor several times.
And I have checked the new processor (core 2 duo e6600), it is working in dell optiplex 780.
