Computer hit by lightning-induced power surge
Alceister
40
About two nights ago, there was an intense thunderstorm near my house, which I didn't really pay much attention to, as I was half-asleep at the time. However, there was suddenly a tremendous flash of light and crack of thunder that seemed to come from somewhere right in front of my house, which momentarily shut off all power. The next morning, I found that two breakers had been flipped, and my cable modem was completely inoperative.
Later on in the day, I found that my computer wouldn't turn on, either. First, I tested the PSU (Antec NeoEco 620c) by plugging the 20+4 into an old Dell (Pentium 4) and the latter managed to turn on, though the absence of an AGP-compatible connector has prevented me from fully testing the PSU's functionality. It was connected to a surge protector, along with my monitor, printer, PS3, and speakers; all of these were also intact. After further inspection, I suspect that my motherboard (ASRock z87 Extreme3) has been damaged by a lightning surge. On the surface, it appears to be fine, but some of the screw holes connecting the board to the chassis have faint traces of a hard white, powdery substance. I flipped the board over to check, and it seems as if the back is somewhat sticky compared to the front, with grease-like smears that did not seem to be present before. Otherwise, there seems to be little obvious damage, compounded by the dark colouring of my motherboard's PCB.
At this point in time, I wish to confirm my suspicions, and I want to know whether or not I may be correct. The lightning induced a power surge which traveled from the coaxial cable leading into my modem, which got fried, traveled through the ethernet cable leading my router without frying the latter, but then went from my router to my computer through an ethernet cable, and then fried my motherboard.
Presently, I am uncertain as to the full extent of the damage: the PSU seems to be functional, the RAM (2x4 GB Corsair Vengeance LP), CPU (Intel Core i5-4670k) and the GPU (XFX HD7870 Core Edition) have not been tested but appear intact, and various cooling mechanisms are in working order.
This or whatever else being the case, I would like to have further advice on what I should do.
Do you have a volt meter? You could do the PSU test and take voltage readings. I did this once and the supply checked out. However when it was installed back into the system bad things happened. I doubt you CPU, RAM, or GPU got damaged the motherboards are designed in such a way to protect those parts from EMI. If you had a micro center near by I would try and pick up a cheap motherboard and power supply to test the components on.
Either way I agree with LB23. No way did the power surge jump from router to wifi access point to computer without damaging the WiFi access point. Either the power supply is not grounded or the power spike circuitry failed it should be replaced anyway. At the very least get a surge suppressor power...
If your modem and router are dead then it could be. But If the router survived then it just went through the psu and killed the motherboard. A jolt through the router strong enough to kill your pc would have killed the router to. A PSU can take a bit and still work after shorting out a motherboard. The modem should have grounded out the jolt to prevent such a situation.
Then why is it that my other electronics, which were attached to the same surge protector, remain fully functional?
Yes and no. I tried two different power cords, and once from the surge protector and again from a wall socket. The test on the old Dell involved plugging the 20+4 and the 4+4 power connectors into the Dell motherboard; the IDE drives went unpowered. The PSU successfully powered on the Dell BIOS screen, though the computer did not boot because I left the IDE drives unconnected, though I will note that the fans in my case started spinning again. Whatever else, it seems to show that the PSU is functional. To what extent however, remains uncertain.
I will add that upon further inspection, there also appears to be discoloration around one of the screwholes of my motherboard, near the I/O panel.
At this point in time, I don't know if it is worth having a shop check the system, because I don't have another system with which to check the condition of the components on my computer. I also have no friends who are able or willing to lend me their computers for testing.
Either way I agree with LB23. No way did the power surge jump from router to wifi access point to computer without damaging the WiFi access point. Either the power supply is not grounded or the power spike circuitry failed it should be replaced anyway. At the very least get a surge suppressor power strip instead of the simple ones with a fuse in it. They have ones that come with a huge insurance warranty protecting against lightening strikes. It happens way more than you think.
Alceister you can eat a dik and im done helping people on this add infested web paged. to many people pick the best solution of the people feeding what they want to hear yet the people that answer the truth gets ignored. I am done with this BS web page. toms is no longer about support and just about the adds. I look at a article about tech and see 12 adds about drama NO ONE WITH A BRAIN GIVES A FUK ABOUT. keep selling out toms and we will go elsware. If you really thing you are the only web page worth it check out your comp overclock.
