Computer is getting BSOD and not sure how to read bluescreenview any help would be appreciated
Zakary_1
Commendable
Dec 12, 2016
These are all the file dumps that it has noticed so far
Dump File : 121016-9156-01.dmp
Crash Time : 12/10/2016 2:58:01 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 00000000`00004477
Parameter 2 : 00000000`deadbf07
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : Wdf01000.sys
Caused By Address : Wdf01000.sys+3a501
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+14a6f0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\121016-9156-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 14393
Dump File Size : 261,900
Dump File Time : 12/10/2016 2:58:50 PM
Dump File : 120916-7906-01.dmp
Crash Time : 12/9/2016 2:34:03 AM
Caused By Driver : vwififlt.sys
Caused By Address : vwififlt.sys+1940
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+14a510
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120916-7906-01.dmp
Major Version : 15
Dump File Size : 545,748
Dump File Time : 12/9/2016 2:34:50 AM
Dump File : 120816-7750-01.dmp
Crash Time : 12/8/2016 11:02:22 PM
Caused By Driver : bcmwl63a.sys
Caused By Address : bcmwl63a.sys+150bb1
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120816-7750-01.dmp
Major Version : 15
Dump File Size : 545,660
Dump File Time : 12/8/2016 11:03:04 PM
Dump File : 120816-8250-01.dmp
Crash Time : 12/8/2016 2:19:18 AM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : ffffaa0c`c0a22dd0
Parameter 2 : 00000000`000000ff
Parameter 4 : fffff801`757edc64
Caused By Driver : hiber_iaStorA.sys
Caused By Address : hiber_iaStorA.sys+86eb9
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120816-8250-01.dmp
Major Version : 15
Dump File Size : 110,080
Dump File Time : 12/8/2016 6:53:02 PM
Dump File : 120716-7843-01.dmp
Crash Time : 12/7/2016 8:09:09 PM
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120716-7843-01.dmp
Major Version : 15
Dump File Size : 553,836
Dump File Time : 12/7/2016 8:09:48 PM
Dump File : 120716-9468-01.dmp
Crash Time : 12/7/2016 1:50:00 PM
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff806`240e0c7a
Parameter 3 : ffff9601`5c6d0658
Parameter 4 : ffff9601`5c6cfe80
Caused By Address : bcmwl63a.sys+150c7a
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : bcmwl63a.sys+150c7a
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120716-9468-01.dmp
Major Version : 15
Dump File Size : 545,796
Dump File Time : 12/7/2016 1:50:50 PM
Dump File : 120416-8562-01.dmp
Crash Time : 12/4/2016 2:20:23 PM
Parameter 1 : ffff8f05`78b297d0
Parameter 4 : fffff802`a5259c64
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120416-8562-01.dmp
Major Version : 15
Dump File Size : 109,568
Dump File Time : 12/4/2016 6:26:12 PM
Dump File : 120316-8078-01.dmp
Crash Time : 12/3/2016 3:15:27 AM
Parameter 1 : ffff8c8b`fea0c310
Parameter 4 : fffff803`7cbf1c64
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\120316-8078-01.dmp
Major Version : 15
Dump File Time : 12/3/2016 5:30:19 PM
2 caused by bcmwl63a.sys (Broadcom WiFi Driver wireless driver, Broadcom Corp), i would look on your motherboards web site and see if new WiFi drivers unless you use a WiFi adapter in which case, look for drivers for it.
vwififlt.sys = Virtual WiFi Filter Driver - oh look, another clue about WiFi
what motherboard do you have? it looks like you need to update wifi and chipset/sata drivers
can you do this to create a minidump:
Can you follow option one here: http://www.tenforums.com/tutorials/5560-bsod-minidump-configure-create-windows-10-a.html
and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD
that creates a file in c/windows/minidump
copy that file to documents
upload the...
upload the copy from documents to a cloud server and share the link here and someone with right software to read them will help you fix it :)
Yep you have a few problems, looking at the txt dump file as said.
There is an Irq conflict between the the Wi-fi adapter running on your system, and also believe it or not the hard disk drive of your system.
I am presuming that one of your Hard drives in the system, or used as the boot drive with windows os installed on it is a Western digital hard disk drive.
As said by Colif if you have just installed windows or it was installed over the last few weeks or months, or was pre installed.
You should run the chip set installer and drivers package for the brand and motherboard model number you have.
Also in the bios of the motherboard check that the memory of your system is set to run at the right speed, that the memory timings and the voltage setting for the memory modules are set right.
By checking with the details found on a sticker of the memory modules.
Make sure Xmp mode is enabled.
That any option to do with memory hole remapping is enabled.
And also that the type or mode of memory is also set correctly.
You may have an option in the bios of support for ECC enabled memory. Or for running unbuffered standard memory.
If using unbuffered memory, make sure the option for Ecc enabled memory is set to disabled.
But enabled if your memory does have Ecc type memory listed on the sticker of it.
Motherboard is ASUS ASMXVIIIHERO and my WiFi adapter is ASUS PCE-AC68
I checked for any updates to the motherboard as well as the WiFi adapter and uploaded the files here -> https://www.dropbox.com/sh/8t6d1ju9g0avr3g/AACgjwGihFIixjTYZ3mI1Xyma?dl=0
I hope I did so correctly :) Thank You very much for your help
