Computer monitor not displaying, and a red light.
Mattmsk001
5
So i had to move my computer to another room the other day, and today i am putting it back, so after i finish, putting everything back, the monitor display doesn't work, so after trying to find a solution, i decide to try resetting my ram, which i believe i did correctly, then since that didn't work, i decided to to reset my bios, by removing and reinserting, my CMOS battery, that also did not work, and now there is a red light underneath "Boot_Device_LED" and the monitor does not work, the computer does appear to be booting up successfully though, as everything inside works, i am able to use caps lock, the main issue is the red light and the display.
Umm Just try to place the hdmi or whatever cable in the graphics card slot (which can normally be found at the bottom of ur rig) instead of the motherboard slot.
