When i got my graphics card i put it in plugged my video cable in turned on my computer and downloaded the drivers everything worked fine. Then I try turn it on again and my monitor says no signal.My monitor only has VGA input and my graphics card only has DL-dvi-d , hdmi and display port output. so i got a dvi-d to VGA adapter.
-this is what iv tried:
-moved Ram into different slots
-moved graphics card into different PciE slot
-i borrowed a different monitor for testing with a hdmi input and tried with an hdmi cable into my graphics card that worked fine
-then i tried with my dvi-d to VGA adapter into that same monitor it worked the first time but the following times just said no connection
these are my specs:
gtx 1050ti 4gb
msi Z370-A pro
500w psu
LG 20M38A monitor
Dvi-D to VGA adapter
possible problems?
the fact that it worked first both time makes me think it could be software
possibly faulty adapter but why would it work both times on the first try
I know little about computer these are just geusses using logic,
these are my specs:
gtx 1050ti 4gb
msi Z370-A pro
500w psu
LG 20M38A monitor
possible problems?
