Computer not going through post? Suspect PSU
darkjediofdoom
4
I just built my computer, and then I connected the monitor. I pressed the power button, and it didn't turn on. I checked all the cables, and I unplugged the ODD, SSD, HDD. It still didn't work. However, my PSU fans weren't spinning, and I didn't see any LED's. If it helps, I didn't hear any beeping.
My build is as follows :
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
CPU Cooler: Arctic Cooling Freezer 7 Pro Rev.2 45.0 CFM Fluid Dynamic Bearing CPU Cooler
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard
Memory: Crucial 12GB (3 x 4GB) DDR3-1600 Memory
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($57.99 @ Mac Mall)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI Radeon R9 270X 4GB TWIN FROZR Video Card
Case: Thermaltake Versa H35 ATX Mid Tower Case
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer
My PSU is a Solid Gear Solid Gear Basix Series 600W ATX12V v2.3 and EPS12V v2.91 Power Supply.
Thank you in advance for any help.
darkjediofdoom
4
Yes.
darkjediofdoom
4
Thanks for all your help. It turns out that not only was the PSU bad, but so was the mobo
I got a Corsair 500x and a Asrock z97 killer instead. It works like a charm
