Have used this build for over a year, other day the computer would not turn on (hit case power button, no display, fan noise, nothing).
Follow the steps of disconnecting the PSU from everything but fans, and using a paperclip to short the green and black wire on the 24pin connector. Doing this yielding the PSU fan spinning up as well as the fans in my case the PSU was plugged into, so PSU seems to be doing fine.
My question is what and how to test next. I know the PSU is good so is the motherboard the next culprit? What are the steps to testing if a motherboard is good or bad?
This is the motherboard I have: ASRock X79 Extreme6 LGA 2011 [http://www.newegg.com/Product/Product.aspx?Item=N82E16813157289]
Thanks for any help!
