Computer not starting with 8GB/more than 2 sticks of ram vs 4GB (WORKS) PLEASE HELP!!
AaronNazzy1
50
Hello all,
I have a huge issue that I need help rapping my head around. I am so frustrated, because I just bought new ram for my PC and ever since I have added it in my PC crashes.
You might be wanting some system specs at this point, here they are:
CPU: AMD Phenom ii X4 965 3.4gHZ BE
GPU: NVIDIA GTX 750ti FTW
HDD: 500gb
Power Supply: 650W
RAM: 8GB
The issue I have having is this, I just bought new ram and I added it in so I can make my previous 4GB RAM to be 8GB RAM, but the problem is when I add the new 2x2gb ram sticks, I crash before windows even loads, sometimes after it loads and in game all the time.
But what I am confused about is, I have 2x2GB sticks in now, plus the 2 new ones to make 8GB, but the new ones I bought are the exact same RAM sticks, so I know it's not a RAM problem, the motherboard I am using I looked up and supports up to 4 slots and a total of 16,000 MB or 16GB.
Please help me, I tried clearing CMOS, changing RAM Timing, (not voltage as I don't want my system to show no display again,) and I even re-installed my OS.
BTW: I have a Windows 7 Professional 64-bit OS.
PLEASE HELP!!!
Well it says it like this when I have four sticks in: DDR2, DDR2 and that's it? I don't know if that means it only detects 2, but rarely when I am able to get into the desktop, I press WINDOWS KEY + PAUSE|BREAK and it brings up the system information which shows 8GB available.
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
Which motherboard do you have? It seems like the mobo is detecting only 2 sticks and the OS is detecting 4 (sounds like it needs a bios upgrade/flashing)
Edit: Don't flash it yet, try booting into safe mode and if no issues occur, let me know
Note:There should be 2 different colored ram slots. Try putting in the first 2 ram sticks into the same color slots and then the last 2
Ok the motherboard is a bit old, but it still supports all my parts and works great, it's a TA790GXBE BioStar Motherboard.
Also I don't want to try booting in safemode yet, because it takes some time to remove the case, then put the ram in and take it out each time, is there anything else I can try or does this NEED to be done to make sure it works via safemode. Can I do it later?
If it works fine in safe mode for a long time, there could be other issues/error that can be found in windows event viewer to deduce the problem
By opening the pc and reseating the ram sticks by color first (first 2 sticks in the yellow slots, other 2 in the white slots, power on pc afterwards etc.) you can get lucky and the issue is solved quickly
Ok I'll do that now, I'll be back in like 10 minutes or I'll just see if I can get into the internet in safemode, I'll try what you said, then report back!
Sure thing, and one more thing. Try "safe mode with networking" to be able to access the internet
Ok so, I couldn't even get to the message where it said "Safe Mode" at all. All it showed was Start Windows Normally and Launch Startup Repair. Either way, it doesn't even get past the loading windows thing where it shows the common red, green, blue, and yellow flag windows logo.
What do I do?
Tried startup repair twice with the 8GB in and it crashes at loading Windows Files?
It boots, and I have 3 different Windows Installation disks with the Product keys, Windows 7 Home Premium 32-bit, Windows 7 Home Premium 64-bit, and the one I have now (Windows 7 Professional 64-bit.)
Let me try to rephrase that
It doesn't boot to login to windows anymore, correct?
No it does not with the 8GB, but it does with 4GB.
Duh! I forgot I could do this thanks. I'll start in safemode and I'll report back once I do.
I had tons of trouble booting, it freezes when it shows my PC Specs and then doesn't boot at all. I waited for 10 mins and nothing happened. :/
This is in safemode with 8GB btw
Ok I'm on right now with 8GB installed and the color thing worked, it boots, but it has done this before, at this point it would crash at around 4-5 minutes of being in any game no matter how big or how small. And when it does the speakers make a really bad screeching noise.
Ok here's an update, I used the computer normally and it performed great, I went into the Steam game: Rocket League, I got in a match and played for around 2 minutes and it crashed, no screeching sounds, just crashed, should I check event viewer?
Here's two errors I got around 10 minutes ago when it crashed, not sure which ones are the ones that caused it or if it's both?
1.) The description for Event ID 2001 from source NvStreamSvc cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
2.) Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Does this mean anything to you? Because it sure as heck doesn't to me?
