Computer Parts Advice
PaddyWoodcraft
4
I want to build a new computer for video editing using programs such as adobe premier pro, final cut pro, Photoshop and after effects. I have licenses for some of these program on mac so would like the computer to dual boot windows and mac os mavericks as a hackintosh.
This is what I have come up with, could someone please give me advice if this is an appropriate build for my needs, reason for the four hdds is to set up a raid 10 array. I would also like some advice if the power supply I selected has enough wattage for expand ability, so I could in the future buy a second gpu for sli or other extra parts.
http://uk.pcpartpicker.com/user/PaddyWodcraft/saved/3kJkcf
I am looking at spending around £1500, I already have peripherals.
looks good you might want to go with a bigger water cooler or air cool your I-7 (You can actually get lower temps with a 212 evo air cooler than a 12omm rad. Also if you are going to RAID all of those drives you might look into WD reds they have built in data loss protection for RAID setups that the baracudas dont
