amatuer
So I am building my own computer for the first time and I'm not sure about the parts I am going to use. If you think there is something wrong with the parts or I can get something that's better please say.
Here is the parts:
computer case - Zalman Z9 plus
graphics card -ASUS EAH5450/DI/1GD3 Radeon HD 5450
Power supply - JEANTECH 400W ATX Power Supply Unit
Hard drive - Seagate OEM 500GB Barracuda 3.5 inch 7200.12
Internal Hard Disk Drive
optical drive (disk drive) - Samsung SH-203B
CPU - AMD Phenom II X6 1100T
Motherboard - Asus M5A78L-M USB3 HDMI
RAM: 8GB set
I will be using the computer for games and i am also on a fairly low budget.
if you are on a low budget, drop to 4GB.
higher clocked quad core, not the hex core - better for gaming
lose the jeantech psu, quality seasonic 500W, or other good quality psu
the 5450 is very poor for gaming, try to get to 5850 at least.
What resolution, what budget, what country
diellur
1,345
Make sure you get 2x2GB or 2x4GB of RAM, it's meant to work in pairs. When you assemble it, your motherboard manual will tell you what slots to use.
+1 on the PSU and GPU. Always, always, always get a decent PSU (says me, who's used generic in the past! But it's important. Try and get one that's 80+ certified, it's more efficient).
Sky03
273
Let's try this:
$361 http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.660856
Includes
1x Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply (Model:Sonata III 500)
1x ASUS P8H61-M LE/CSM (REV 3.0) LGA 1155 Intel H61 Micro ATX Intel Motherboard (Model:p8H61-M LE/CSM (REV)
1x Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor BX80623I32100 (Model:BX80623I32100)
1x G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBNS (Model:F3-10666CL9D-4GBNS)
1x Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (Model:ST31000524AS)
Then add one of this: XFX HD-685X-ZNFR Radeon HD 6850 $150 (with $30 MIR)
or this: SAPPHIRE 100314-3L Radeon HD 6870 $170 (with $20 MIR)
