Computer problem please help!
compatible? yes
quality? no
balanced? wayyyy off. i hope you dont buy this.
what is the machine going to be used for?
If its gaming lose the build you made and get this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.89 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($136.95 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($48.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive ($66.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($50.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card ($213.98 @ Newegg)
Case: Corsair SPEC-02 ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($15.98 @ Newegg)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor ($141.47 @ B&H)
Total: $1024.91
Generated by PCPartPicker 2015-09-14 02:31 EDT-0400
here is another build for you. no overclocking needed, small form factor, good at editing, and a excellent video card.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($79.89 @ OutletPC)
Memory: G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2133 Memory ($89.99 @ Newegg)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card ($334.98 @ Newegg)
Case: Cougar Spike MicroATX Mini Tower Case ($33.99 @ SuperBiiz)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($16.41 @ OutletPC)
Monitor: Asus VH238H 23.0" Monitor ($111.99 @ NCIX US)
Total: $1073.01
Generated by PCPartPicker 2015-09-15 00:06 EDT-0400
oh itll run them better than that. itll have no problem with ultra maxed out settings at 1080p with 50+fps.
Radeon R9 390 8GB 1080p Benchmarks vs GTX 970/R9 390X/R9 290
https://www.youtube.com/watch?v=vSDQzlKDYq4
the xeon processor is basically a non-overclocking version of the i7-4690k, helping to bring down the price.
the xeon processor does not have onboard video like the i7-4690k, also helping to bring down the price.
there isnt a cpu/gpu out there yet worth the upgrade from what i made you (based on your budget). that should last you at least 3 or more years.
-the xeon is still a very strong, top of the line processor.
-the r9 390 will last a long while with its 8gb vram. the newest games only take 5gb vram max on 1080p.
those are both high quality parts.
changed the ram to 8gb and removed the cd/dvd drive. the msi r9 390 is a few $ cheaper. keep in mind 16gb is optimal for editing, but you can buy more or change it out easily later. you can always add the dvd drive later too. that is the least important part. everything can be downloaded these days. made a few other tweaks.
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($40.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($47.78 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card ($329.98 @ SuperBiiz)
Total: $999.49
Generated by PCPartPicker 2015-09-15 01:03 EDT-0400
even though this is in your price range and will work flawlessly, i highly recommend saving the extra 70 for the previous xeon build i linked if you want the most out of your money.
