So I built my own PC a few years back and it was running perfectly when I had my GTX 760 and old parts from a pre built I bought years before that. I've since upgraded everything except for the original hard drive. Since I upgraded my GPU from the GTX 760 to the GTX 970 i've had nothing but problems. I'm not sure how much information you'll need, but before upgrading the GPU I bought my new motherboard (specs below) and had saw other people have bios chip issues so I swapped that out and it had fixed the problem it was having which I can't recall what it was. I also sent back the motherboard before changing the bios chip. Now, back to the 970 which I bought. I had a problem with the computer infinitely booting into windows. It would spin on the launch screen, but would never fully boot into windows. It would take me to the page where you can reset the PC and such. I reinstalled windows at least 5 times with nothing be resolved. I decided to send back my GPU hoping it was just a faulty GPU. Sadly that wasn't the case. My friend told me his friend was having a similar problem to mine which was whenever I just use the computer it would freeze with pink and green, sometimes blue, pixels everywhere. It would either fix itself and happen again within the next 5 minutes or it would automatically restart. After the restart it would either remove my video driver and go to the lowest resolution whilst only utilizing one of my two monitors or it would restart and do the above until the video driver gets removed. I will provide images of both of my screens when one of these crashes occur. Hopefully someone can help me out because I've spent a lot of time looking through forums with similar problems just to have none of the help me.
Thank you,
Joe
Specs:
Processor: Intel Core i7-4820k
Motherboard: Asus Rampage IV Gene
GPU: MSI GeForce GTX 970
RAM: x4 8GB Corsair Vengeance
Freeze Images:
Thank you,
Joe
Specs:
Freeze Images:
