Computer running in slow motion
Mar 20, 2018
Hey everyone.
I am having the weirdest issue I have ever seen.
My computer is in slow motion. Mouse traverses the screen absolutely perfectly, everything is running just like normal, but in super slow motion. I turned on a couple of games, I am getting constant high fps, and animation are normal. But my characters are in super slow motion. And outside of games windows open and close in super slow motion.
Nothing is running hot, and CPU/Memory Usage isn't very high and isn't spiking.
I completely reformatted the machine today and just got everything reinstalled. And everything was working fine...Until this happened.
Does anyone have any ideas?
Go into the mouse settings, you can set the speed....
Start> Control panel > look in the upper path bar, click on the arrow ">" after "control panel."
this opens a drop down menu
Then click "All control panel items"
Click: Power Options
Click: Show Additional Plans
Click: The arrow, check the box that says "high performance."
Click: Change Plan Settings
Turn Off Display: Never
Put Computer to Sleep: Never
Click: change advanced power settings
Hard Disk : turn off hard disk after: Never
Wireless adapter Settings: power saving mode Setting: Max Performance
Sleep: sleep after: Never
Allow Hybrid Sleep: Setting: Off
Hibernate After: Setting: Never
Allow Wake Timers: Setting Disabled
USB Settings: selective suspend setting Setting: Disabled
PCI Express Link Power State Setting: off
Display: turn off display Setting: Never (turn off monitor manually if desired)
Multimedia Settings
When sharing media : prevent idling to sleep
When Playing video: Setting: optimize video quality
Now: Click "OK"
Computer> system properties > Now open the Device Manager
Click On: mice and pointing devices ">" click on the arrow
Double Click on HID complaint Mouse
Click: power management tab
UN-check the box that says: "allow computer to turn off this device to save power"
Now open all devices on the list, and turn OFF all power savers, for every device, as above.
Now Click " OK"
Antivirus: set for "multimedia mode."
This prevents updating from interrupting your media. If you do not have an antivirus with this feature: get a different antivirus.
Set ALL updates to: manual. This prevents an update from eating resources that you would otherwise be using.
Free antivirus from internet: I do not recommend that you install any "free" security tools.
I do not recommend installing "cleaner," "sweeper," "driver helper,"or any free junk from the internet.
Avoid any download which claims to "fix" your computer.
I recommend that you use a professional all-in-one security application - not a free download.
Please consider, when you install multiple security programs, they can conflict with each-other. That's why you should use "all-in-one" professional security.
Restart the computer
Open Bios
Turn off Cool and Quiet (if AMD processor) Save and exit bios settings.
Restart Computer
Problems should be fixed now.
hello friend,,
please i need your help now i`m facing the same problem my pc suddenly runs with this slow motion problem and i have installed win 7 all over again the problem was fixed that was yesterday now the problem is back again can you please tell me how you fixed yours ??
