Okay so this is my first time posting I hope I'm doing everything right. Been a long time lurker and really appreciate your help. I've been able to solve all my problems based on other people's questions until now. Here it goes:
I built my own rig about a year ago and it started acting up recently. What happens is my screen will "freak out."
*This is flashing and the lines sometimes move around*
Now I have a second display which is set up as an extended screen and everything functions normally. If I'm watching a video it will continue to play and I can even drag things from the primary screen over and keep working. If I unplug the main display or change it to 1 display (the working screen) then that screen gets the same problem. The only solution is to press the power button on the tower and allow it to reset.
Specs:
CPU: Intel Core i5-2500k 3.30GHz
GPU: AMD Radeon HD 7870 GHz Edition
Display: Dell UltraSharp U2312HM IPS-Panel Black 23" 8ms
Secondary Display: iSymphony 37" LCD TV
Motherboard: ASUS P8Z77-V PRO LGA 1155
This has happened probably 6 times in the last 2 months. I've noticed (not positive that everytime) it seems to be when I'm watching a video on project-free-tv on the secondary screen is when it happens. However normally when I'm using my computer this is what I'm doing so that could be a confound. I'm kind of assuming this is a GPU problem but it's strange that it only affects one monitor at a time. I don't have a backup GPU to try and I'd rather not buy a new one unless I have to. I've updated all my drivers. Any help here would be awesome. Thank you all so much!
Specs:
