I've got a friends computer here that I'm trying to fix, I'm hoping someone can help a little.
The computer was working fine, and a few days ago it completely turned off, and upon reboot:
Motherboard: H-Alpinia-RS780L-uATX
OS: Windows 7 64 bit
My friend says that if he trys turning it on and off multiple times that eventually the keyboard lights will come on and everything works fine until he turns it off, but he says that when it is on that he can use the
restart option and the computer will restart perfectly fine, but if he chooses shut down then it wont work when he tries turning it back on.
The computer turns on and the light on the motherboard is lit green and all the fans are spinning and you can hear the hard drive working and the cd drive works fine but there is no display on the screen
it just stays "No signal" and also the lights on keyboard / mouse aren't turning on like usual when the computer starts, the mouse flashes for less than one split second once i click the power button but
then it turns off, and if I unplug it and plug it back in when the pc is on the light flashes again and then turns off, however, if I put my USB key into there and put it in extremely slowly (otherwise it wont work)
then my usb flashes up and everything but it doesn't do that with the mouse or keyboard.
I have tried a different monitor, different cables, a brand new power supply, I've reseated the ram and cleared the contacts, I've also tried unplugging everything and just keeping the vga cable connected to the onboard graphics card and only having 1 ram card of 2gb, and alternating between the 4 places to put the ram and also tried 2 other rams of the same type. I've also ensured that everything is plugged correctly and that the power supply connectors in the motherboard are in right. I've also tried turning it on without any ram at all and it doesn't show any display of course but the computer does beep.
