Hey Everyone,
Im building a computer for my mother-in-law and I am running into a really strange problem. I have built my own computer before but I am kind of a Noob when it comes to this thing so please excuse the noobness.
Anyways the problem is that I put the computer together and when i powered it on the fan's and everything powered on and then after about 3-4 seconds everything powered down. When I turned the power on/off the same thing would happen. Of course I assumed it was a faulty PSU because I unpluged and replugged everything back in to no avail.
After a short while I found a way to turn it on but it is not really effective. If i plug in the the Power LED cable from the case to the motherboard the system turns on but if I remove it before it shuts itself on the computer will stay on. I was able to load Windows 8 and install a bunch of software well it was on like this. If I plug the Power LED cable back in when the computer is running the computer will shut off.
I'm not sure what exactly the issue is but I no longer suspect the PSU I'm thinking either its a motherboard issue, or a idiot builder issue.
System Specs:
Case: Velocity IW-Z583 Micro ATX Mini Tower, Black w/ 400W Power Supply
Core™ i5-2400 Processor, 3.10GHz w/ 6MB Cache
500GB Barracuda 7200rpm SATA III w/ 16MB Cache
P8B75-M LE w/ DDR3, 7.1 Audio, Gigabit Lan
Kingstong ValueRAM 8GB DDR3-1333MHz CL9 Dual Channel Kit (2 x 4GB)
Any help would be greatly appreciaed
System Specs:
