Computer Specifications Help for adobe photoshop and coreldraw applications
CharLs06
20
Hello guys, this is my first post. I really need your expertise and opinions regarding this one. I'm going to build my first computer, purely on Adobe Photoshop Cs6 and Coreldrawx7 applications only. Below is the following options:
FIRST OPTION:
1. Core i5-4460 3.2Ghz 4th Gen
Haswell Refresh
2. Asus H81M-D 4th Gen
3. 1pc. 8GB TEAM DARK DDR3 1600
4. Marshall MAL3500SA-T72 500GB
32MB Sata 6Gbps
5. ZOTAC GTX 750 2GB GDDR5
(ZT-70708-10M
6. Samsung 24x DVD-RW Sata
7. CVS 2812E PC CASE W/ 650W PSU
8. AOC E970SWN 18.5" LED Monitor
SECOND OPTION:
1. Core i7-4790 3.6Ghz 4th Gen
Haswell Refresh
32MB Sata 6Gbps
5. Samsung 24x DVD-RW Sata
6. CVS 2812E PC CASE W/ 650W PSU
7. AOC 18.5" LED Monitor
As you notice the first option is Core i5 with 2gb Gpu and the second option is core i7 but no dedicated gpu both are 4th gen. So guys which is which better of the two given options and why?
Yes, the Intel Skylake socket 1151 CPUs have better integrated graphics, but Broadwell, if available in your area, has WAY better Iris Pro graphics. Honestly though, considering it's probably not available to you, I'd highly recommend just doing something like this. You'll have to find the parts on sites that are available to you, but anything along these lines would work well for what you need.
The GTX 750 TI offers capability far beyond what any of the integrated graphics can offer from either Intel or AMD, supports CUDA and will do all you need. You might need to change a few things if some of the parts are not available through vendors in the Philippines, but most of them should be as I selected brands known to be widely...
The 4790 will be better in graphics applications due to the additional hyperthreads and the fact that it has a larger CPU cache, 8MB smartcache versus 6mb smartcache on the 4460. Both have the same integrated graphics so there will be no advantage there. For the applications you intend to run, a discreet dedicated graphics card would be highly recommended whether it's a gaming or workstation card. The HD 4600 graphic iGPU is rather weak for high end graphics applications.
It's fine for watching HD video, but will suffer in 3D, rendering and large resolution images with many layers.
Possibly. Are you in the US or another country? I ask because the HD 530 graphics on the newer Skylake processors or the Intel Iris Pro graphics on Broadwell might be a much better choice if you're going to use an iGPU, so if the price difference isn't terribly great depending on where you are, it's probably a much better platform for you.
I'm from Philippines, I could consider looking at another intel i7 cores. Below are the available cpu's with their corresponding prices:
Socket 1150( 4th Gen)
Discount Cash Price : Core i7-4790 3.6Ghz 4th Gen Haswell Refresh - 14890.00
Discount Cash Price : Core i7-4790K 4.0Ghz 4th Gen Haswell Refresh - 16590.00
Socket 1151(5th Gen)
Discount Cash Price : Core i7-6700K 4.0Ghz(Turbo 4.2Ghz) 6th Gen Skylake - 16790.00
Discount Cash Price : Core i7-6700 3.4Ghz 6th GEN SKYLAKE - 14990.00
The GTX 750 TI offers capability far beyond what any of the integrated graphics can offer from either Intel or AMD, supports CUDA and will do all you need. You might need to change a few things if some of the parts are not available through vendors in the Philippines, but most of them should be as I selected brands known to be widely available in other regions than the US. Do NOT purchase any cases that come with included power supplies. The cases are generally incredibly low quality but more importantly, the power supplies are ALWAYS the worst of the worst.
Especially in off brand units like the one you had outlined. Considering the power supply is the most important component in the machine, you absolutely don't want to skimp on that. The wrong PSU selection can make for a very bad day, or year, and end up costing you some of the hardware you invested in when it fails. I can't overstate how important this is. You definitely want an SSD as the primary drive for the OS. This will be very beneficial to your graphics applications and for general performance. If you want to add a secondary data storage drive for files and backups, that's a good idea as well depending on whether your budget allows for it or not. If not, you can always add a second drive at any point along the way.
The E3 Xeon 1241v3 is the exact same processor, primarily, as the i7-4790, but without any integrated graphics.
CPU: Intel Xeon E3-1241 V3 3.5GHz Quad-Core Processor ($263.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard ($68.89 @ OutletPC)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.33 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card ($99.99 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case ($37.99 @ Micro Center)
Power Supply: Antec 450W ATX Power Supply ($32.99 @ SuperBiiz)
Total: $676.06
Generated by PCPartPicker 2015-10-24 03:16 EDT-0400
I saw the following gpu's in store. Is this good enough for my i7 4790k rig. and which of this two? Any of this two wont cause bottleneck?
**Asus GT730 2GB GDDR5 64BIT 384 CUDA CORES(GT730-2GD5-BRK)
**ZOTAC GT730 1GB GDDR5 64Bit(ZT-71111-10L)
Generally, for non-gaming systems, bottlenecks aren't REALLY an issue. At least not in the same way they are for gaming machines. You'll still be limited, but by the GPU card performance in your application, not by being comparatively weaker than the CPU. The GT 730 is actually rather weak. It's probably enough for what you're wanting to do now, but if you get into anything slightly more advanced, you're probably not going to happy with the performance and capabilities. It's not much better than some of the newer iGPUs, if it's any better at all.
I probably wouldn't recommend anything tiered lower than the GTX 750 or higher, or R9 270 or higher, to be honest. Photoshop and CorelDraw can pretty thoroughly chew up resources, but they CAN run on lower end hardware, just not as well.
I might do something like this.
CPU: http://pcx.com.ph/components/intelr-coretm-i5-4690k-processor-6m-cache-up-to-3-90-ghz.html
Motherboard: http://pcx.com.ph/components/gigabyte-ga-b85m-hd3.html
Memory: http://pcx.com.ph/components/gskill-ripjaws-8gb-f3-12800cl9d-8gbxl.html
PSU: http://pcx.com.ph/components/antec-vp450p-450w.html
GPU card: http://pcx.com.ph/components/palit-gtx-750-1gb-ddr5-128bit-oc-stormx-graphics-card.html
And whatever you want to do with storage drives and case. It's an option anyhow. I wouldn't go with the GT 730 for a graphics machine though. Not even a low end one.
How about this build?
1. Core i7-4790k 4.0Ghz 4th Gen Haswell Refresh
2. Asus H81M-D 4th Gen or GIGABYTE GA-B85M-HD3
(TDKED38G1600HC901)
pcpartpicker.com/part/team-memory-tdked38g1600hc901
4. ZOTAC GTX 750 2GB GDDR5
5. Corsair PSU 450w
pcx.com.ph/catalogsearch/result/?q=corsair+vs450
About the motherboard ASUS is much cheaper compare to GIGABYTE GA but if thier are big difference when it comes to performance I'm willing to purchase gigabyte.
Every there is doable except the Corsair 450w power supply. You can make a much better purchase than that. The Corsair CX, CS, VS, and RM units are tiered rather low and we see a lot of premature failures on these units when paired with systems that incorporate discreet GPU cards or overclocked systems, as seen here:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
I'd look for an Antec VP-450, EA-450 or pretty much any XFX, Seasonic, Super Flower or another Tier 1 or Tier 2 unit as listed on the Tier list linked to above.
I agree with getting a tier 3 or better psu. Actually, hyperthreading is not beneficial for Photoshop. The two most important things are having adequate RAM and single core frequency. A recent test (no longer published) comparing the Skylake i7 6700K with the i5 6600K actually showed the 6600k to be better at smaller Photoshop tasks and equal to the 6700k at larger Photoshop tasks. I don't know why the 6700K did not pull ahead- perhaps the test was faulty? At any rate, the Haswell 3.6GHz might be slightly better than the i5 3.2GHz, perhaps up to 10% improvement.
https://www.pugetsystems.com/labs/articles/Adobe-Photoshop-CC-Multi-Core-Performance-625/
I would increase your RAM to 16GB (matched).
The video card will probably make a slight improvement now, and probably more in the future as Adobe moves functions to GPU processing. I would go for the GTX 750ti if you can with the new Maxwell processing engine. You can always add a video card later, so there would be no harm in trying the on-board processing first to see how it does for you.
https://www.pugetsystems.com/labs/articles/Adobe-Photoshop-CS6-GPU-Acceleration-161/
I would probably go with your first option, but increase the RAM, choose a better PSU, and get the GTX 750ti in place of the 750 (or try on-board processing first). If the cost is not an issue, go ahead and move up to the i7.
Here is some Photoshop testing with the i7 4790K:
http://www.tomshardware.com/answers/id-2836099/computer-specifications-adobe-photoshop-coreldraw-applications.html
That Pugetsystems article is contradictory. First they say cores/threads are not beneficial because most Photoshop processes are single or lightly threaded, and that Photoshop is not optimized well for threaded processing or utilizing additional cores, then they turn around and say it IS, up to 8 cores, and all of the CPUs they recommend are models with at least 4 cores and 4 hyperthreads. While I generally applaud most of their testing and articles, whoever wrote that one must have been smoking dope. A thing either IS or IS NOT, beneficial. If it's beneficial SOME of the time, then it's beneficial PERIOD.
Multi-threaded actions hit a point of diminishing returns after around 6 CPU cores, and most completely stop improving after 8 CPU cores. This includes effects like color mode conversion, many blurs, hue/saturation, brightness/contrast, and shadow/highlight. The best multi-threaded effect (converting to Lab Color mode) had a decent multi-threading efficiency of about 94%, but most of these effects had an efficiency closer to 80% which isn't so great.
One thing we want to point out is that the raw number of cores different Photoshop effects can utilize is only a starting point when choosing a CPU for Photoshop. Even though Photoshop may at times be able to use eight or even ten physical CPU cores, our testing has shown that it doesn't typically do so very effectively. Because higher core CPUs also tend to have lower operating frequencies, this means that the best CPU for Photoshop will be one with a moderate core count but a high operating frequency.
After examining the results of our testing, we believe that - of the Intel CPUs available at the time of this article - the following three models should give you the best possible performance in Photoshop CC:
Recommended CPUs for Photoshop CC
Intel Core i7 4790K 4.0GHz Quad Core 8MB 88W or
Intel Core i7 6700K 4.0GHz Quad Core 8MB 95W
Intel Core i7 5930K 3.5GHz Six Core 15MB 140W or
Intel Xeon E5-1650 V3 3.5GHz Six Core 15MB 140W
I've found it to be beneficial in my own usage, AND since they were likely using a test bench rig and not running any other processes or applications during their testing, which most people WILL be doing, I'd say their results in this case are probably not as relevant and conclusive as most their testing usually is.
Also, Adobe's own dev team has indicated that MANY processes, but not all, in Photoshop, DO advantageously use hyper or multi-threading when it's faster. So some functions of Photoshop do use it while others do not.
CorelDraw definitely uses threaded processing to it's advantage as well. Saving and running various effects and processes are much faster on a quad core or higher chip than they are on say, a G3258. All that being said, it IS doubtful more than four cores/threads will ever be utilized in either of those programs which is why I suggested the much less expensive i5 might be a good choice and would allow for a more powerful GPU card, which is likely to have some affect on graphics performance as well, depending on the type of image processing you're doing.
If you will have tabbed web browsing, multiple simultaneous applications or other utilities running at the same time image processing is going on in either of those applications, it's likely you'll benefit from a 4/4 chip, especially considering windows is going to be running some processes of it's own in most cases and on most systems.
Personally, since it uses both the strengths of a fast core AND somewhat uses threaded processes, I'd say any four core or higher chip, unlocked, and overclocked, is a very good option. A 4690k or 4790k, clocked at about 4.5Ghz on a halfway decent board like the Gigabyte Z97X-Gaming 5 or ASUS Z97-A, would probably benefit from the faster core clock in all areas where threading does not offer an advantage.
Let me be clear that by hyperthreading, I am referring to virtual cores, not physical cores. Here is test they did showing the superiority of the 6700K over the 4790k in Photoshop (it's about half way down the page):
https://www.pugetsystems.com/labs/articles/Haswell-vs-Skylake-S-i7-4790K-vs-i7-6700K-641/#CPUPerformance-LightroomCC
I do agree with you that the hyperthreading may be beneficial if you are running other applications simultaneously with Photoshop. Of course it is your right to disbelieve the testing done at Puget, though I think that they do excellent work.
As far as CorelDraw, I cannot comment.
I just noticed that the i5 6600k versus i7 6700k test is back up:
http://www.tomshardware.com/reviews/skylake-intel-core-i7-6700k-core-i5-6600k,4252-5.html
Skylake is indisputably faster in the synthetics. Real world use rarely equates to synthetics though, but it may be somewhat representative of expectations. Prices for Skylake chips in the Philippine's may not be realistic for this situation compared to Haswell refresh though, plus, Haswell Refresh and even Haswell are still significant players and very relevant as options for new builds. Barring any hardware failures down the road I'd expect a Haswell refresh i5 or i7 to still be entirely capable of worthy productivity for graphics and other workstation functions in five to seven years.
I was actually referring to the Tom's testing, which used PCmark8. It may not be a fully synthetic test as it does use some actual program processes, but they are still not generally representative of actual usage. You can't really account for image quality, number of layers, specific photoshop processes being run, bit depth and other factors that may vary drastically from user to user, with a benchmark utility. Still, the comparative result IS indicative to some degree, so it's worth factoring in regardless.
Oh, I see. I wish someone would do some actual testing of Skylake i5 versus i7 in regards to Photoshop. If it's already been done, I haven't seen it yet.
I do as well. I'll ask our resident mod/editorial staff member about it and see if they can come up with anything. Regardless, none of those choices is BAD, so any of them should work well for you Charls. Again, I think in this case I'd probably just go with an i5 Skylake chip or an i5 Haswell refresh and opt for a higher tiered GPU card using the money you'll save. Maybe even a workstation card if price allows it.
Thank you guys Darkbreeze and Bearman you really help me a lot and I learned many important aspects, especially in PSU I thought cheap and expensive only differentiates in brand name, which is I was wrong. I'm leaning towards i5 4460 Haswell Refresh with zotac gtx 750 2gb 64bit (if gtx 750i version not available) and the save money instead of 8gb ram, I'll add another stick all in all 16gb ram. If I choose i7 build it cost me P37,510 while i5 only around P29,810 with the same build installed only differentiate in CPU cores. Did I made the right decision? Any thoughts?
I think that would be a good machine and if you get into more complicated graphics later, 3D or high end stuff, and find the GPU card isn't cutting it, you can always upgrade that but the rest of your system will already be very capable for a good long time. The 16GB of RAM is also a good idea. Just be sure to get a matched set of 2 x8GB modules. You don't really want modules that don't come in a matched set, together. You also don't want 4 x4GB as the more memory modules that are installed, the more stress there is on the memory controller.
Like darkbreeze noted earlier, you really can't make a bad choice here. It really depends if you have a set price and expect the computer to last you for a few to several years, or if you don't mind putting in more money in perhaps 6-12 months. If it were the same price, I would be inclined to get the i7 and no video card and see how it goes, knowing that you will likely add a video card within the next year. It's not a clear cut decision, though you'll have a great machine either way.
Honestly, I've had little problems running web type 2D graphics on Intel HD 4600 graphics on occasion. I wouldn't want to HAVE to do so, but you could if it was absolutely necessary. The GTX 750 is significantly better than that, so you should be fine until and unless you get into higher resolution, multiple layer or 3D stuff, or very involved processes using a variety of high end plugins. Print graphics is a different beast though.
Thank you guys,,, both of you are very helpful. @ Bearmann thanks for the tip maybe i could consider build using i7 4790k core without discrete gpu installed, the price will cut down to 32k+. About the mobo I'm going to use ASUS H81M-D since the GIGABYTE is too expensive.
BTW. i7 4790 3.6ghz is much cheaper compare to 4790k 4.0ghz both supports hyperthreading but diff. in clockspeed .4 differential is noticeable either in games and photo editing?
