computer starts no beeps but monitor show message that it is working fine check power supply or monitor cable
Nae Nae
I replaced a power supply in my PC now it boots with no beeps however the monitor shows a message that the screen is working properly check power supply or monitor cable? what can I do
Also, make sure your speaker is hooked up properly. If it's not, you won't hear any beep codes. Have you reseated your components to make sure everything is seated correctly.
There are 2 power connections on the motherboard - a 24 pin and a 4 or 8 pin near the processor (top left). Make sure the 4/8 pin is connected properly.
