Computer turns on when power is connecter
ce123ben
15
I have an amd motherboard with an athlon x2, and 4gb ram. It worked fine for a while, but then today, i unplugged my hard drive and reconnected it because i wanted to move it in the case because of heat. Anyway, when I plugged the power cord back in it just turned on. The cpu fan started moving, and the lights on the front and in the power supply went on. It didn't post though, its just on. I went to the extreme of unplugging everything, so I have the mobo connected to the psu, out of the case, no ram, no cpu. Same thing, when i plug the cord in the light and fan in the psu turn on, even when i have no case, thus no power switch connected. Please help.....
The only thing I can think of is that you may have dislodged or misconnected the wires that join the motherboard to your case, such as the tiny POWER wires that join your motherboard to your power switch. If you accidentally connected those across a closed circuit, it would be like someone constantly holding the power button.
Which would cause your machine to power up as soon as you plug it in, and would probably cause it to shut off a few seconds later (because holding the power button down while the machine is on causes it to turn itself off).
Just a guess, but worth checking carefully.
Thank you for replying, I actually disconnected the motherboard from the case entirely, because I originally suspected the case as the problem. Nothing changed though, I have another case, i'll put the mono in it when I get home
