Computer Upgrade and No First Boot w/ Red Blinking Light
BrightDarkness
9
Specs.:
Upgrades:
CPU: i7-8700K
MOBO: AsRock Z370 Killer SLI/AC
RAM: Corsair Vengeance LED DDR4 2666, 2 sticks of 8GB (CMU16GX4M2A2666C16)
CPU Cooler: H55 Corsair
Upgraded Components:
CPU: i7-2600K
MOBO: P8Z680-V Pro
RAM: DDR3 Corsair Vengeance 16 GB
CPU Cooler: Corsair Hsomething
These components were not upgraded.
PSU: Corsair RM 1000
GPU: GeForce GTX EVGA 1080 FTW
SSD: Samsung Evo 850 1TB
HDDs: 2 Seagate 1TB drives
So, I am not new at computer builds for starters. Second, sorry if this thread is in the wrong area.
Okay, so I installed all of the new components and turned on the power and a light to the left of the SATA connector surrounding the "AsRock" labeled block turned on white. It then proceeded to turn red and flash. I booted anyways and no screen came up (display connected to GPU) and the computer proceed to go into a cycle of turning off and back on.
I though it may be the RAM placement. I do not think so now. I tired slots 1 and 3 and 2 and 4. Neither cause anything different, expect when in slots 2 and 4 the RAM in DIMM 4 does not light up. I am now in slots 1 and 3. I also tried booting without a GPU, which changed nothing.
Thank you so much in advance.
There maybe a list of fault codes in the motherboard manual.
It doesn't sound like RAM as it wouldn't usually loop. Try with one stick of RAM in slot 1 and disconnect everything...test adding each device one at a time and by process of elimination you'll find the problem...
Sounds like it's not seeing the CPU--that's what usually causes the on-runs a few seconds-off-wait a few seconds-on cycle. Do you have a speaker connected to the motherboard? A bad/badly seated CPU will give you 4 beeps between cycles (I think).
BTW, I assume you mean a AsRock Z370 Killer SLI/AC
I think the red blinking may just be the RGB on the board. I looked at a thread on the AsRock website and that seemed to be the case. The powering on and off may be the main issue. I am currently trying more stuff.
I have no speaker, but just checked the CPU. No bent pins and it is seated properly.
