Hi i have a problem that my pc sometimes when i push the power button it wont start but then after many tries it does start... I even tried to use the reset button and even the screwdriver trick...and i am not sure where the problem is coming from and i need help PLEASE
I suspect you need to replace your PSU but it would be better first to inspect your ATX power cabling, are these all rooted properly in their sockets? Also check the front panel wiring on your motherboard, is it resting firmly on the pins or is it shortening, exposed wire touching another expose wire?
Have you checked the power button on your case? Does the button feel as it should mechanically when you press the button to boot up your PC?
I recently had an issue with my Enermax Platinum 1050W PSU, I was getting a loud crackling sound, at first I thought it was the pump on my 4 year old AIO. So I replaced the AIO, nope it wasn't that. Then after many discussions on other PC forums, somebody suggested, it could be the chipset fan on my X570 motherboard, so I got a replacement chipset fan from eBay. £35 for a small tiny plastic fan, outrageous, nope it wasn't that.
So everything finally pointed to Enermax PSU. I replaced it with a quality EVGA PSU and the problem disappeared.
Best to do the due diligence first, check the wiring inside your case, check for any foreign objects like a loose screw inside your case, then when you have done your sanity checks and mitigated the other possibilities, move on to the PSU.
