Computer Won’t Work After Reset and Blue Screen of Death
zhiffy
Commendable
Mar 17, 2018
25
Hey!
So after I restarted my computer, I turned it and it was stuck in the black screen with a small white loop in the bottom center of the monitor. It then took about 3 mins till I reached the login page and I thought everything was good. It wasn’t because whatever I do, everything is delayed and I can’t even open anything.
Some background info is my computer had the blue screen of death with the message “BAD SYSTEM CONFIG INFO”. I fixed it by going into command promt in advanced options. After this, everything has been so slow and nothing has been working. Please help!
What did you type into command prompt? Just going in there wouldn't have fixed anything.
See if this helps speed PC up - http://www.tomshardware.com/faq/id-3127605/fix-windows-bad-system-config-info-error.html
Slowness at startup means windows is having problems connecting to some hardware, have you checked you have latest drivers for motherboard? Try unplugging all USB devices except mouse/keyboard and see if it starts any faster.
Thanks for the help! The link you gave me made my computer start up again normally!
