First thing's first, I have already replaced the CMOS battery!
The Build:
CPU: Intel 12900k
Motherboard: ASUS ROG STRIX Z690E
Memory: G.Skill DDR5 32gb
Storage: 2TB 980 PRO
GPU: RTX 3080ti
PSU: Seasonic Prime TX-1000W
Chassis: Fractal Torrent
Okay so my computer suffers from a few different issues that I think may be connected by a root issue. The biggest problems are with the motherboard.
The Build:
CPU: Intel 12900k
GPU: RTX 3080ti
- If the computer loses power (unplugged from wall, etc.), it will not boot until I reset the BIOS. It will be an infinite load (it's been a while since I've had to unplug it). Have to hold the BIOS reset on back of mobo, then f1 to get into bios. Very annoying and moving my pc means losing all my settings.
- Computer will randomly blue screen, address/highlighted file in BlueScreenView is ntoskrnl.exe. It will also bluescreen when I leave my computer locked instead of powered off. I notice the most common way to get a BSOD is by locking my pc. It's not every time, but it feels around 15-20% of the time a lock means BSOD. Usually I only notice it occurred by how everything suddenly starts loading when I login as if it was first boot up (compared to when I actually lock and sign back in).
- Any attempt of OC memory to get the advertised 6000 MHz leads to constant bluescreens/failure to boot.
- Every now and then, red blinking red lights will trigger on my GPU, which I believe means there's not enough power to the GPU. However I believe this is triggered sometimes when I'm powering down. I had a previous 3080ti that randomly died a little while back, got it RMA'd and the new one has this issue quite a bit. I don't remember at this point if my old one had this issue as it died pretty early.
- If I plug my DAC/AMP for my headphones into my motherboard using S/PDIF, the audio will cut every 5 seconds. Tbh I'm not sure if this one is related but it's quite annoying, and any fix for this is hugely appreciated. I use a FIIO K5 PRO.
