So I made it a project of mine today to move my router to my desk where my gaming computer is so I can take advantage of wired Internet, but it's not as simple as it appeared. I've been working on this turd bucket for over 5 hours now and have gotten nowhere, basic rundown on the computer is:
I5 4690k
Asus formula vii
Gtx 980ti
16gb trident X ram
I've been using the wifi module that came the the mobo since I built the computer earlier in 2015 and it still works fine, but the ethernet port won't do anything, I've uninstalled and reinstalled multiple versions of the driver for the built in Intel i218v ethernet adapter, the hardware itself in device manager shows up normal however I get the constant "unidentified network no internet connection" message, I can disable wifi it does nothing, I've uninstalled my antivirus, I've tried different cables, I've tried ipconfig commands, manually entering ip/dns info, drivers from the motherboard support site, drivers from the Intel support site, Windows 10 drivers, Windows 8.1 drivers, powering everything off and on, disconnecting power to the tower for a period of time, checked every network setting ninety thousand times, poking it with a stick, swearing at it, buying it dinner, etc, etc, etc. Nothing has made even the slightest bit of difference. When I check my network info the IP address it comes up with it nowhere near a proper ip for my router (actiontec v2000h router/modem from Telus) the subnet mask is wrong and gateway is empty, it literally seems like it has no idea if it's hooked up to a router or a ham sandwich. Any chance anybody has any other things for me to try before I give up? I love building computers but when a guy blows all this money to build a nice gaming rig and it can't do something as simple as go on the Internet when you plug in an ethernet cord it's a little bit of a downer... Oh and the ethernet ports do work on the router, I had me and my wife's ps4's plugged into it before I moved it to my computer.
I5 4690k
Asus formula vii
Gtx 980ti
16gb trident X ram
