Computer won't power on - power supply works fine
Aug 28, 2018
Computer won't power on.
Tried using a different battery, power supply, power switch, to no avail - there is no power coming in.
I got a (used) new motherboard and same problem.
Ran the paperclip test (successfully) on my power supply.
I tried putting a screwdriver by the 2 pins for the power button - also didn't work.
Sorry, forgot to add.
I had this issue, ran a bunch of tests etc. determined that motherboard was at fault - ordered a new (used) motherboard from a respected seller on ebay - same issue
______________________________________
Motherboard is Acer-H11H4-AD2
Computer is Acer Aspire ATC-710-UR56 (link on newegg)
Aug 28, 2018
Yes, and yes.
24 pin (one piece) is connected
4 pin cpu is connected
Aug 28, 2018
No beeps, nothing - no power coming through (PSU fan, power button light - both don't turn on)
It's a factory (generic) computer - non custom build (not sure the correct terminology here) so specs are same as on newegg.
