Ive had my pc for about 3 months now and all of the sudden i decides not to turn on. I thought it was a power issue since when i put a srewdriver to the cmos everything turns on for a second and then suddenly turns of. I then replace the old psu which was an evga 600 watt with a corsair 600 watt and when everything is plugged in the pc still wont turn on at all. I have in the pc an intel i5 with a gtx 1070. Also when i slowly pull out the 24 pin connector the fans turns on a bit and the gpu light flashes on for a sec. If you vuys have any idea what the pro lem might be pls let me know because im probably gonna get a new mobo. My original mobo is an asrock h970 pro4.
