[SOLVED] Computer won't turn back on, click noise from PSU
Jan 28, 2019
My PC randomly shut off when I was on youtube, and will not turn back on. When I try to turn it back on there is a weird click noise from the PSU. Has been running fine for 2 years. Please Help
Have tried starting up without GPU and changing outlet.
Replacing the PSU would be good place to start, as no other troubleshooting is possible until you connect a working PSU. That may well be all that's needed.
Nothing cheap mind, needs to be a quality brand (Corsair, Seasonic, EVGA etc) with at least the same power ouput.
I have a NZXT Hue and when I turn on the power supply the rgb from the motherboard lights up as well as the Hue, would it still be a power supply problem?
