Computer won't turn on... Help! Really need help!
samb_ch
112
Before the problem happened my PC is randomly shutdown. I tried to turn it back on several times and it show various BOSD then restart. i thought i shouldn't try open it again which may cause further damage. I thought it's about PSU failure.
A few week later i've got a new PSU to replace. After replaced PSU computer won't turn on at all(even fan not spin) when i pressed power button. I tried remove Graphic Card to see if it is the problem. "I start press power button SURE the fan spin, it powering up!, but no not even a few second after that i try again and it worked flawlessly no BOSD".
My hope was gone when i shut it down and it won't turn on again!. Finally, i figured out that it is not my Graphic Card. Even i put Graphic Card back i still have a chance to turn it on.
It is strange where i double quote. Before it is possible to turn on i need to press power button twice times. First, fan spin then shutdown. Second, It start to run without any problem(i test it many hour, also run game).
Spec:
MB: Asrock H77M
CPU: i5 3470
GPU: Power Color HD 7950 PCS+
HDD: Sea gate 500GB
RAM: Adata 8GB 1333MHz
PSU: SilverStone Strider Plus 700W (New)
1) test your hard drive..... take it out and hook it up to another rig if you have to.
http://www.hdsentinel.com/download.php
2) take your memory out and test them one by one see if it helps. Then you want to memtest them to see if any are throwing errors.. 1 pass is good enough.
3) get a known good PSU see if that helps.
4) is your system timing good? if thats changed then maby you have a bad CMOS battery.
5) while your hard drive is out if you needed a second computer to teast it... go ahead and virus scan it with the second computer.
6) run A CHKDSK IN DISK MANAGEMENT.
I never heard any pop and bad smell happen though
I checked everything on mobo all seem good all capacitor i mean
1) my harddrive is fine i already checked with hd sentinel
2) i will try
3) my psu is new
4) yes my cmos battery is dead. is that possible to make pc won't turn on?
5) my computer is safe from virus. i'm not sure if virus able to stop pc from even power up.
Thank everyone for your time
