Televirtual
I had similar (not exactly same) but similar, and I solved this way:
MY COMPUTER WAS NOT TURN IT ON- AT ALL
- I took cables away (every cable) from the mobo
- After that -no cables connected except the 24 pin- I connected the power supply and turn it on and it turned on!
- I realize then that I have a short circuit problem-
- I put back each of the cables- one by one, and at same time turning on the PC to see where the problem was.
- When it was the time to connect one of the cables to the mobo I turn the PC on but it did not, so I realize that it was the problem- (one of the cables had short circuit)
- That small cable was the big problem, and was only a led cable -not so important for the PC to work-
- So I disconnected that cable and not used anymore- and my PC is fine now.
SO THE LESSON is: when you install cables in the MOBO I believe you have to be very careful- cause can cause a short circuit. And in order to diagnose properly you have to do it ONE BY ONE step.
