Hello, I've been working on upgrading my build and ran into some trouble when on first power up I didn't get post or video signal. I assumed the motherboard was shorting somewhere and tried breadboarding to check all my components, finding that I only hear post when the CPU is not plugged in. I called Intel, ran some further diagnostics and was told to send back the defective processor for a replacement. Upon receiving my replacement, I threw all the parts back together and am back to where I started. No display, no post. My SSD, HDD,GPU, Fans, LEDs are all responsive, however I have no USB power and the power button LED doesn't come on. The only thing I can think of is a very small amount of thermal grease leaked onto the bracket under my CPU and looks like the tiniest drop could have gone into one of the pin holes for the CPU on the mobo. I don't even know if that would matter because the thermal grease isn't visible or channeled across 2 pins. I don't know if its possible that my CPU socket is defective? Or my CPU power cable is defective? Any help is greatly appreciated, my specs are as follows:
MSI Z97S Krait Edition (New,
Upgrade)
Intel i7 4790k (New, Upgrade)
ASUS GTX 980ti Strix
Crucial 12gb RAM (3x4gb)
Thermaltake TR2 RX 850W (New, Upgrade)
Seagate 2TB 7200 rpm HDD
Crucial 120gb SSD
Thermaltake Level 10 GT Snow case
Upgrade)
Crucial 120gb SSD
