Question Confused To Where My Loud Fan Is
jar00d
54
I unplugged all of my case fans to find out which fan is the loud fan.
I open two programs but come to find out that I still have a fan (labeled MB Fan #1 on Corsair Link.) that apparently is running at 2300-2800RPM. I believe that to be the culprit of the noise. How do I fix this? I don't even know where that fan is, since I unplugged all my case fans. And I know it cannot be my cooler because there's a whole separate section in the program dedicated to it.
Any help or ideas? None of my fans are four pin.
I have tried fixing it through the BIOS but I have no idea what I'm doing or how to set a fan curve.
My motherboard is Gigabyte GA Z97 Gaming 7.
View: https://imgur.com/MzIfRas
Well, it must be a CPU fan or a GPU fan. What else could it be if all the case fans are unplugged? By the way, there's probably a way to assign a name to each fan in the UEFI (BIOS) and in Corsair Link. Not Maggie, Jim and Charles, but Top Front Case, Bottom Front Case, CPU, etc.
if you are using air cooler that can be the culprit.
