Confusion between recovery drive and system image
pcgeek21
9
From what I understand, recovery drive is basically just a barebones version of system image.
System image allows you to recover everything on your system, including multiple drives. On the other hand, recovery drive only allows you to copy your most essential files from your system drive.
Is my understanding correct?
A system (or disk) image is a complete copy of a hard disk partition. That image is contained in a single file. Providing that you imaged your system (usually C: drive, it contains the boot files, operating system, programs and user data. If you run into problems that you can't fix, or your computer's been rendered unbootable, you can restore the image and your computer will revert back to how it was when the image was created.
A backup is usually a copy of important files such as documents, e-mails, photos, and music etc saved to an external hard drive, memory stick, or CD etc. An image file can sometimes be classed as a backup because it's usually possible to extract individual files and folders from it.
A system image is likely to...
A system image is likely to be bigger than a recovery disk because it also contains all the extra programs you installed and also your data files. So, yes you are essentially correct, Hope this helps
