Connect a 1280x800 notebook GPU to a 1920x1080 LED TV with an HDMI cable - FAIL!#@?$
stamenvalchev
51
Hi guys,
I might be missing something here and that's why I decided to ask. So I just bought a big LED LG TV (1920x1080) and hooked it up with an HDMI cable to my laptop also with a native 1920x1080 resolution. All worked like a charm. BUT, when I trued to hook up another laptop, with a native resolution of 1280x800, to the TV... the TV wouldn't receive any signal? Any idea where the problem is? Would/could it ever work to be able to send signal from the low-res PC to the LED TV?
Thanks! :)
PS Merry xmas :)
Yes yes ... that's not the problem. I did pres the Fn + f4 and normally on an external monitor it would work. But somehow it does not work on the big tv. As I said, I am doing the exact same thing with both laptops but with the 1920x1080 one it works and with the 1280x800 it does not, so I just dont know what to do? Shouldnt it normally work despite the difference of native resolutions of the screens. As getochkn suggested, the fact that my display can max go up to 1280x800 does not mean the laptop cannot play a full hd 1080 movie and play it on an external device with a higher resolution, sooo.. what gives? :)
Well, it says many things but for resolution it only says the native 1920x1080, and that's it. Doesn't say whether or not it supports 1280x800. Maybe it's cos the GPU on the PC is WXGA 1280x800, which is an 8:5 (or 16:10) ratio and the GPU of the other PC (which successfully connects to the TV) is full HD 1920x1080 which is a 16:9 ratio. See this link for clarification on the resolutions and ratios.
http://en.wikipedia.org/wiki/File:Vector_Video_Standards4.svg
So... still, any idea if this is ever going to work? Is it supposed to work in principle?
It's also evident to me that the PC I am successfully able to connect to the TV has, similarly to the TV, an LED screen with a native 1920x1080 resolution, again, exactly the same as the TV, so... fine. That's all good. But is it not possible to connect the other PC's GPU with native res. of WXGA High Definition BrightView Widescreen (1280 x 800)?
from the user manual
HDMI-PC supported mode
Resolution Horizontal Frequency (kHz) Vertical Frequency (Hz)
640x350 31.468 70.09
720x400 31.469 70.08
640x480 31.469 59.94
800x600 37.879 60.31
1024x768 48.363 60.00
1152x864 54.348 60.053
1360x768 47.712 60.015
1280x1024 63.981 60.020
1920x1080 67.5 60.00
change the laptop to a lower resolution like 1024x768
