Connect a 2-wire Fan to a 4-pin Header without an adapter.
BuBu Shofronea
489
So is it possible ? To connect a 2 wire old fan with no available adapters to a 4-pin header on the MoBo ?
And if yes, there are 4 pins : 1, 2, 3, 4
The Fan is 12 V
In which pin ( 1/2/3/4 ) should i attach the red wire and in which one ( 1/2/3/4 ) the black one ?
The problem is the colours aren't standardized for all. But in general pin 1 is negative and pin 2 is positive. Black goes to pin 1 and red goes to pin 2. Pin 1 should be black.
Yes it's possible since the 3rd and 4th wires are for monitoring fan speed and controlling fan speed respectively. I suggest you get a 2 pin to 4 pin adapter or a 2 pin to 3 pin one and just plug the 3 pin one into the mobo for a simpler solution. For the wiring you can check this out: http://pcbheaven.com/wikipages/How_PC_Fans_Work/
Reactions: iamOne
