Connect external speakers to monitor or motherboard?
usmc21
65
Just got some Klipsch speakers and I was wondering if I should hook up the green audio cable to the monitor or to the IO shield/motherboard ?
Plug the speaker cable in to the motherboard's speaker-out jack.
The audio-in jack on the monitor is for connecting a separate cable from the motherboard's speaker-out jack (by means of a three-way adapter), but that's optional if you're not bothered about using the monitor speakers.
