connect kindle fire to my home wi-fi
Hello!
There should be a password on the back of your router and that should be able to get you into your wifi, if not you can reset the router by pushing a little reset button that can be found on the router, on the back, and this will reset the router to default factory settings, which will then make the password work :)
