H harshal123 Honorable Jul 10, 2013 1 0 10,510 Jul 10, 2013 #1 Hello, Can we connect LCD monitor directly with TV tuner card without PC
Solution hang-the-9 Jul 12, 2013 No, but you could get something like this http://www.geniatech.com/pa/atv100.asp or http://www.geniatech.com/pa/android-tv.asp and use the monitor as a smart TV, although without a tuner. You'd have to use web streaming things like Netflx or Hulu. You do need an HDMI port on the monitor or a converter from HDMI to the connections on your monitor.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Jul 12, 2013 Solution #2 No, but you could get something like this http://www.geniatech.com/pa/atv100.asp or http://www.geniatech.com/pa/android-tv.asp and use the monitor as a smart TV, although without a tuner. You'd have to use web streaming things like Netflx or Hulu. You do need an HDMI port on the monitor or a converter from HDMI to the connections on your monitor. Upvote 0 Downvote Solution
