connect smart TV to lan
Floringh
Hello,
I'm tryng to connect my Samsung SMART40H5203 to my lan internet network.I don't have a router.I use the lan cable that i use on my computer(i have an username and pasword to connect to the internet).Automatic connection doesn't work .(these are data which is used on the automatic connection.
IP Adress 169.254.234.166
subnet mask 255.255.0.0
Gateway:0.0.0.0
DNS server:0.0.0.0
.Can U please help me to manually configure my connection on my tv(what to enter in ip,subnet mask,gateway and DNS). i added a photo with data from ipconfig
Thank you:)
Most SMART TVs are made to connect to a home network that has a router, they don't have the same capabilities of a computer to do a direct connect to your ISP, like inputting a username and password. While you might be able to get it to work, just buy an inexpensive TP-Link router and do it the easy way.
