Connect to WIFI Network with Intel LAN card?
Kyle_77
Commendable
Jun 28, 2016
55
So I have a Intel PRO Wireless 2100B Wireless LAN card. It works with Windows 98 and ME. I have the drivers and installed them, but how do I connect to my WiFi network?(wifi network uses WPA2-Personal)
WEP needs to be enabled on both ends.
The PC and the router.
Intel PRO Wireless 2100B Wireless LAN uses 802.11b Data Link Protocol.
IEEE 802.11b products appeared on the market in mid-1999.
It uses the following Encryption Algorithm:
128-bit WEP, 64-bit WEP, LEAP, TKIP, TLS, WPA
WPA2-Personal is not supported.
System Requirements/
OS Required
Microsoft Windows 2000 / XP, Microsoft Windows 98, Microsoft Windows 98 Second Edition, Microsoft Windows NT 4.0
You might try broadcasting in the open with no security.
How would I connect it to the WEP network?
You'd have to enable WEP in the router.
But that is little better than no security at all.
Where are the settings? In the driver software or in Control Panel?
Probably in the driver software.
Code:
I changed the network to 64bit WEP,I can't seem to connect to the network?
How to enable WEP on PC? Let me send my router settings
