Connect TV Toshiba 32BV502B SPDIF CoAxial out to TEAC CRL600 optical in
MilRob
Commendable
Dec 20, 2016
Am using Digital Coax Phono to Digital Optical Adapter with cables that fit both TV and amp, but sound continues from the TV's speakers.
There seems to be no way of telling the TV to direct sound output through its SPDIF instead of its speakers; and no facility on the amp to pickup sound input from its optical input.
Any ideas would be much appreciated. Thanks. MR
Pictures of the back of your Teac show that there is no optical input.
The adapter you need is an optical digital to analog converter like this one
https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA
Connect it to the Aux input on the Teac.
The optical audio output is not controlled by the TV volume control so if there is no menu option to turn the TV speakers off just turn the volume down.
You may have to turn the optical output on, the TV speakers off, and change the audio output type in the TV menus.
