Connect VGA Silencer's fan to an Aerogate II
Debello
Is there a procedure to connect 9800 Pro VGA Cooler's (VGA Silencer) fan to an Aerogate II. I have seen the procedure for connecting it to the CPU cooler on cooler master website, but I did not find any information on connecting it to the VGA cooler. Any help will be great
I just installed the exact same thing last night :) I have not checked if the vga silencer's wiresetup supports fanspeed-readings (3-pin), if so; I can't see it should be a problematic issue, tell us how you go..
Soltek SL-86SPE-L - P4A -2.4@2.766 - i865PE - 1024mb ddr400@307 w. TT A1165 - Ati Radeon 9700@381mhz 128Mb@626mhz - 600W dualfan(front/rear) PowerTek Psu - maxtor 4K080H4 & 6Y120P0 - samsung sm-352b
you "can" connect the fan to the Aerogate if you please, though monitoring is not possible 🙁 There might be a way to re-wire the cables though; since a 3-pin cable goes from the vga-silencer to the backpanel with the switch, before plugging into the card's psu.
