Connected to Wireless network but not able to connect to internet
goh69
15
Hello,
I have a home ADSL2 Modem Router. I have 3 computers connected to this wireless network and also with Internet access. However, I have 1 notebook connected to the wireless network but saying No Internet access.
goh69
15
Also all the PC and notebooks are running Windows 7.
The ADSL2+ modem router is Netgear DGN3500.
The modem router is surely connected to internet successfully as other PC/notebook connected to the wireless network are able to access the internet.
Only 1 notebook is failing. I have checked the IPv4 properties, it is same as the others. IP Address is obtained automatically.
Any suggestion is welcomed. Thanks.
eibgrad
Splendid
On the notebook having problems...
Hit Windows key + R, copy/paste the following into the box, and hit enter.
cmd /c "ipconfig /all > %tmp%\tmp.txt && start notepad %tmp%\tmp.txt"
This will open a file detailing your network configuration. Cut and paste the contents to this forum.
goh69
15
Hi eibgrad,
Below is ipconfig/all result:
Windows IP Configuration
Host Name . . . . . . . . . . . . : AiLianLoh-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Physical Address. . . . . . . . . : 00-26-22-78-98-45
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) WiFi Link 1000 BGN
Physical Address. . . . . . . . . : 00-1E-64-3C-BD-60
Link-local IPv6 Address . . . . . : fe80::d410:9b8e:67e9:f3b8%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, 28 August, 2012 10:11:29 AM
Lease Expires . . . . . . . . . . : Wednesday, 29 August, 2012 10:11:28 AM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 184557156
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-A6-3F-BE-00-1E-64-3C-BD-60
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{5AE8A96F-8786-4BCA-A9CF-905147777B30}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 18:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Also when I try: Ping 192.168.0.1
I am getting:
Request timed out.
Ping statistics fpr 192.168.0.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Thanks.
goh69
15
Hi eibgrad,
This is ipconfig from a working computer:
Description . . . . . . . . . . . : DW1501 Wireless-N WLAN Half-Mini Card
Physical Address. . . . . . . . . : 1C-65-9D-E1-A6-18
Link-local IPv6 Address . . . . . : fe80::b134:6736:30d5:a694%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, August 28, 2012 9:23:38 PM
Lease Expires . . . . . . . . . . : Wednesday, August 29, 2012 9:23:37 PM
DHCPv6 IAID . . . . . . . . . . . : 337405341
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-88-49-6E-F0-4D-A2-C2-1A-15
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
Physical Address. . . . . . . . . : F0-4D-A2-C2-1A-15
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
Link-local IPv6 Address . . . . . : fe80::c03b:9e7e:3037:c9d8%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.126.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 302010454
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::cdc0:1147:4ce1:3ad%18(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.145.1(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 536891478
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:20cc:2f6a:3f57:fffa(Preferred)
Link-local IPv6 Address . . . . . : fe80::20cc:2f6a:3f57:fffa%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
The Ping to 192.168.0.1 is OK.
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=1ms TTL=64
Reply from 192.168.0.1: bytes=32 time=3ms TTL=64
Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 3ms, Average = 1ms
Thanks.
eibgrad
Splendid
That looks fine too. Both are using the same network settings (gateway IP, dns server, etc.).
Anything else unusual or different about that troublesome laptop? Third party firewalls (Norton, McAfee, etc.)? Is this only a recent problem w/ the laptop, or has it never worked on this network? What is you connect via wire, does it now work?
goh69
15
Hi eibgrad,
This notebook was working fine till recently and I don't remember making any changes to the network configuration.
Even if connected using cable the result is the same.
It has McAfee installed, same for the other working notebooks.
I have done the below using run as administrator but still it does not work.
arp -d *
nbtstat -R
ipconfig /flushdns
Thanks.
goh69
15
It works after Mcafee is uninstalled.
And after that I received an email from Mcafee saying that its recent update may cause connecting to Internet Failed... :eek:
What the.....
