Hi All,
I'm at my wit's end with this, appreciate any help you guys could give.
I've hooked my uncle's computer up to a 3 Connect Wireless Mobile Broadband using a Belkin Wireless Network Adapter. The Network is running fine, the connection is fine, but I can't access the internet at all. I've tried everything I can think of with the results below.
Last diagnostic run time: 05/24/10 15:32:09 HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
warn HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
info HTTPS: Successfully connected to www.microsoft.com.
info HTTP: Successfully connected to www.hotmail.com.
info FTP (Active): Successfully connected to ftp.microsoft.com.
The router info:
SSID: 3-Connect-5983
MAC Address: 64:16:F0:79:13:0F
Encryption Type: WPA
Advanced Authentication: On
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Rory McQuillan>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : McQuillan
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection 10:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Belkin N Wireless USB Adapter #4
Physical Address. . . . . . . . . : 94-44-52-28-29-AF
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
Lease Obtained. . . . . . . . . . : 25 May 2010 11:09:04
Lease Expires . . . . . . . . . . : 26 May 2010 11:09:04
In the Belkin Wireless Networking Utility:
Signal Strength: Excellent
My Computer connected to Router connected to Internet
"Your Network is Running Smoothly"
Wireless Network Properties
Name: (SSID) 3-Connect-5983
Encryption Key: xxxxxxxx
Autoconnect if this network is in range: Yes
Network Authentication: WPA-PSK
Data Encryption: TKIP
In the Wireless Network Connection Properties>Internet Protocol (TCP/IP) Properties tab 'obtain an IP address automatically' is checked, as is 'automatically detect settings' in Internet Explorer>Tools>Internet Options>Connections>LAN Settings
C:\Documents and Settings\Rory McQuillan>ping 192.168.1.100
Pinging 192.168.1.100 with 32 bytes of data:
Reply from 192.168.1.100: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.1.1:
Minimum = 2ms, Maximum = 2ms, Average = 2ms
C:\Documents and Settings\Rory McQuillan>ping 206.190.60.37
Pinging 206.190.60.37 with 32 bytes of data:
Reply from 206.190.60.37: bytes=32 time=230ms TTL=53
Reply from 206.190.60.37: bytes=32 time=231ms TTL=53
Reply from 206.190.60.37: bytes=32 time=251ms TTL=53
Reply from 206.190.60.37: bytes=32 time=914ms TTL=53
Ping statistics for 206.190.60.37:
Minimum = 230ms, Maximum = 914ms, Average = 406ms
C:\Documents and Settings\Rory McQuillan>ping yahoo.com
Pinging yahoo.com [72.30.2.43] with 32 bytes of data:
Reply from 72.30.2.43: bytes=32 time=277ms TTL=53
Reply from 72.30.2.43: bytes=32 time=274ms TTL=53
Reply from 72.30.2.43: bytes=32 time=273ms TTL=53
Reply from 72.30.2.43: bytes=32 time=275ms TTL=53
Ping statistics for 72.30.2.43:
Minimum = 273ms, Maximum = 277ms, Average = 274ms
Try to load through-
Internet Explorer: 'Internet Explorer cannot display the webpage'
(when I run Network Diagnostics it tells me 'Windows did not detect any problem with your internet connection)
Firefox: 'The connection was reset' 'The connection to the server was reset while the page was loading.'
Safari: Safari can't open the page "http://www.yahoo.com/". The error is: "unknown error" (kCFErrorDomainWinSock:10053)
these results are the same whether using www addresses or ip addresses.
The router info:
192.168.1.1
