Hello everyone. I´m building a PC with some old pc parts. I have a ECS-B75H2-M4 Motherboard, which i´m going to allocate inside a Riotoro CR500 case. My old motherboard haves only 1 Sys_fan header to install case fans, which only haves 3 pins. My mobo haves the option (as it´s stated on their manual) to regulate a 3-pin fan speed by changing the fan voltage and this way, the motherboard can get to regulate the fan speed. Then, i need to connect 3 (or 2) of the 4-pin case fans (which are preinstalled on the case) to the only 3-pin sys_fan header, but i want to keep the capability of my mobo to regulate the fan speed by voltage.
How can i achieve this? I´m considering the option of connect the 4-pin fans to this 4-pin hub (https://www.amazon.com/Deepcool-Fan-Hub-Controls-PC/dp/B008YD7B0M?tag=googinhydr18418-21), and then connect the 4-pin input header of the hub to the only 3-pin header of the mobo, but i´m not sure if this way, the 2 or 3 fans that i´m going to connect will be still be able to have their speed regulated by changing the fan voltage at the BIOS settings of the mobo.
Also my case doesn´t feature a slot in which i could install a fan controller. Any other suggestions will be aprecciated. Thanks.
