I am buying a deep cool matrexx 55 add RGB case with 3 fans pre-installed I then want to add an additional cf 120 deep cool fan along with the deep cool captain 240 pro RGB aio the motherboard is an MSI b450 gaming pro carbon ac. I am wondering if I would need to buy a separate fan and RGB hub or if the one that comes with the case would be enough to set up all 4 fans and the 2 aio fans
https://www.newegg.com/Product/Product.aspx?Item=N82E16811853066&Description=matrexx%2055&cm_re=matrexx_55-_-11-853-066-_-Product
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856111&Description=cf%20120&cm_re=cf_120-_-35-856-111-_-Product
https://www.newegg.com/Product/Product.aspx?Item=N82E16835856120&Description=deep%20cool%20gamerstorm%20pro&cm_re=deep_cool_gamerstorm_pro-_-35-856-120-_-Product
