• Our team is working to address issues posting quotes or media to the forums. Please bear with us as we get this sorted out.
Question Connecting ARGB lights to motherboard
Jul 22, 2021
I have an MSI B550 tomahawk and it has 2 ARGB headers but I have 6 ARGB fans and 1 ARGB wire from the aio pump for a total of 7 connections that need to be made. The case I’m using comes with an rgb hub that connects to the PSU but it only has 6 spots for connections.
  1. Is it safe to hook up 6 to the hub on one motherboard header? Then use the 7th wire on the 2nd header?
  2. do I get another rgb hub and connect 4 to 1 hub and three on the other?
im worried about burning out the headers on the motherboard as this is a brand new build.
I also would like to know that since the hub connects to the PSU for power does that eliminate the chances of burning out the header on the motherboard? I’m new to all of this so any help is appreciated.
